samsquanch
- Jun 3, 2009
I'm about to build a DC-Coupled B1 Buffer for my preamp, the preamp will also contain a 4 input 4 output switcher, which will have the buffer between the in's and outs. I will also use relays to put a volume pot in the path for when I switch to the output for my power amp. The question becomes where will the buffer be most effective for the power amp, pre or post the volume pot? In my head it's after the pot, as this is just how I've always seen gear schematics, pot->circuit. But which is more impacted by an impedance change, an output (a low impedance) or input (high impedance), it would seem that the ratio of constant impedance (gear input/output) to variable impedance (volume pot) would be better if the pot followed the buffer.
I'm probably over thinking this, and should just put the pot before the buffer and be done with things.
Any thoughts or links to reading on the subject are appreciated.
