pcyeh
- Nov 11, 2002
I am currently building Mr. Millet's hybrid amp. There are two buf634 on the board. In Mr. Millet's design, he uses heatsink with each buf634. Since I never install a heatsink before, I have some question. The hole on the heatsink is exactly alligned with the hole on the buf634. Therefore I assume that there might be some screw required to connect the two so that the heat can be transmitted to the heatsink directly through the screw rather than the air. I don't know if my guess is correct or not? If I am right, where should I get this screw? It didn't come with the buf634 nor with the heatsink. Should I just pick any screw from the hardeware store that fit the hole size? Or should I get some special one from the electronic supply stores? Can I get it from Radio Shack? Thank you very much for your help!!
