I can feel the bass from my Monster Turbines somewhat. It does depend on the type of music and recording quality though. I don't think a quality pair of IEMs would ever trump a quality pair of regular head phones in the bass department. It's just physics.
Break-in for Klipsch Custom 3?
- Thread starter drtwofish
- Oct 31, 2008
i think your just not getting a proper seal, really try the olives they should give you a tight seal and give you the bass you want
drtwofish
- Jul 17, 2009
slowpickr, I did consider the turbines...it was a tossup between them and the Klipsch, maybe I flipped wrong
Mark, you've been a big help to me, I'd like to give the olives a try - any place you would suggest ordering them from? Are they just the black foam shure replacement tips? Thanks!
- Oct 31, 2008
any place to order, erm not really unless your in the us ebay might be a good option as everywhere else seems to price gouge on these sorts of things
The tips I mean
glad to be of help
The tips I mean
glad to be of help
drtwofish
- Jul 17, 2009
Thanks! Now if only they made combo packs so I could figure out my size...
- Oct 31, 2008
well they dont, but id suggest small as the customs go rather deep if you want to shove them all the way in
or you could try to get a shure fit kit, that would have all three sizes and a few other tips too
ZARIM
IP address matches SNOOP_DOGG and HFAUDIOPHILE.
- Dec 24, 2006
Try this SRS WOW SANDBOX software n sync it again. It will give you more oomph and you can change settings( free trial).
drtwofish
- Jul 17, 2009
FWIW, I ordered a set of Olives from an amazon marketplace supplier for $13 - figure I'll give 'em a try and see if they help. Now I only hope the smalls fit me - if not, I'll have 4 pairs for sale for cheap
FYJX
Previously known as MaoDi
Now altering the sound of a recording is just Devilish in my opinion...musicians and singers spend so much time getting just the right tones and recordings and we people out here ruin it by EQing the sound. This is of course my opinion
Originally Posted by ZARIM /img/forum/go_quote.gif Try this SRS WOW SANDBOX software n sync it again. It will give you more oomph and you can change settings( free trial). |
