Zack W
I got them. They are not angled, I thought they were from the picture, but I didn't have a preference. Getting them installed is not for the faint of heart. Out of my 4 rings, one got destroyed. I think it might have been damaged before I started, but I definitely finished it off. In desperation to make them fit, I tried trimming down the diameter of the damaged one to see if it would go into the pads that way. It did, but the the clips were completely covered by the pads' retaining flap, or whatever that part is called. I did finally get an un-damaged, un-cut ring into the pads. I started by stretching the pads' flap by hand, around and around to loosen it up. Then I just worked it around the ring until I finally got it. Everyone talks about being careful not to damage the pad, but I think not screwing up the plastic rings by bending them is a bigger concern. I found that my tire mounting skills came into play a little bit.
First impressions? Well, the bass is not reduced in volume, but I think it has been muddied a little. Actually, I think the whole range has been muddied just a little. It's hard to describe, it's not veiled exactly, just a little blurry. Vocals seem to be more in the foreground, which I actually like. The vocals sounding like they're coming from behind the rest of the music has been my one and only negative thing I keep noticing with my HE-5LE. I think the over all tone is slightly warmer, which is OK. I was hoping the sound stage would open up a little more, but I think it's about the same. The drivers are not only not sitting farther away, but they're actually closer. Even though the pads look very thick, the foam is much softer, so they crush right in.
Comfort will take more time to figure out. So far though, I'm not impressed. Because the foam is so soft, I feel the drivers are touching my ears and I don't that. But I need to give them time and see what happens. I do think they're a bit warmer too, which isn't good.
