Brainwavz HM5 Pads (Different Colours / Velour / Leather)
Jun 19, 2015 at 1:43 PM Post #151 of 270
Which version of the 770s?  How did your T90 change?
32 ohm LE.
The T90s...hard to say precisely, because I also added a small piece of tissue beneath the foam driver cover before swapping pads. That definitely tamed the treble a bit even with stock pads, but the most noticeably change from that to the leathers was the sense of extension and tight impact to the bass, and a little bit further reduction in treble, probably due to the mesh cover.
Jun 19, 2015 at 2:23 PM Post #152 of 270
I figured leather pads would be a bad idea on T90 since it uses velours by default.  Mine's unmodified, and I don't intend to change that.
Jun 19, 2015 at 7:53 PM Post #153 of 270
Really? IME velours or cloth pads tend to bring out more treble presence and reduce bass slightly vs leather due to a less complete seal; since the bass on the T90 is naturally a bit south of neutral in the lowest registers, and its overall signature is on the bright end of the spectrum, I thought of leathers as a natural match to even out the profile.
Jun 20, 2015 at 1:41 AM Post #154 of 270
And in my experience, putting pleathers on headphones that normally use velours muffles and kills the sound.
Now that I put a pad on one side, I do find the treble tamed and the sound doesn't muffle as I expected.
I wouldn't call T90 "south of neutral" by a good bit.
Jun 20, 2015 at 11:10 AM Post #155 of 270
The sound is fairly full/warm, but bass below 40hz is definitely less than neutral IMO on the T90, especially compared to true flagships like the T1 or HD800. Swapping for leathers definitely adds a bit to the deep punch in the lowest registers (kick drums, extra deep synthesized bass, etc).
IMO the T90 survives the slight "muffling" due to already being pretty bright.
Re: headphone design, nearly all DT770s come with velours, while the newer 32 ohms come with leathers, and all use the same drivers; I think it really boils down to purpose use (leather pads give better isolation) and, most importantly, personal preference.
Jun 20, 2015 at 2:39 PM Post #157 of 270
  Did anyone try the hybrid yet? Are they identical in size to older versions?
What about isolation and how hot they are?
I want those angled ones, wish I'd known about them before I bought the regular leathers for my T90...hybrid looks cool too, might grab those for my 770s.
Jun 27, 2015 at 2:59 PM Post #159 of 270
Can anyone confirm if extra thick pleather pads are indeed memory foam?
Where to get them in Poland ?
Yes the extra thick ones are made of memory foam (both pleather and velour).
Best place to get them is mp4nation :
http://www.mp4nation.net/
I believe they offer free international shipping .
Jun 27, 2015 at 3:05 PM Post #160 of 270
Free shipping to Poland ?
That would be extraordinary ! thanks for the info
Would get some headphone stand too ! Any recommendation ?
So which should I get ? Angled or normal ? Anyone reviewed angled ?
Any my question about memory foam stands.
Jun 29, 2015 at 12:22 AM Post #161 of 270
Hi,
You can contact our Polish distributor as well: sklep@audiomagic.pl
Hope this helps!
Jun 29, 2015 at 7:37 AM Post #162 of 270
I just did. They will have new delivery this week :)
Will get memory foam pads and velour pads. Angled are too risky without trying them.
Is there any way to get those plastic circle mounts?
Jun 29, 2015 at 4:00 PM Post #163 of 270
So when will the angled hybrid pads be available in the US
