Aug 12, 2013 at 5:06 PM Thread Starter Post #1 of 2
Trancecommunity
Hi
Just looking for an answer from someone familiar with Bluetooth headphones.
If i connect FSL Zero bluetooth headphones to a laptop what does the sound quality depend on?
Is it the headphones that process the signal completely or does the internal soundcard make a difference?
Thanks
Aug 27, 2013 at 3:35 AM Post #2 of 2
As far as I know (I'm in the research process for set myself) the sound quality depends on the internal DAC/amp of the headphones (they have DAC/amp combo internally) and the codec used. (due to low bandwidth, Bluetooth sends audio in a lossy encoded form) I've heared of a new slightly better codec that's currently not supported by Apple devices. Just my 2 cents...
