Poimandres
- Dec 23, 2009
What exactly is your issue? Are you ripping an original cd or a burnt copy? If you are ripping from a copy and that copy was not ripped accurately and then burnt accurately including the cue sheet and drive offsets you will not be able to achieve a bit perfect rip. If you are ripping an original and you would like to recreate bit perfect copies will will also need the drive offsets set up properly and the cue sheet, currently this is where eac has the advantage as dbpa does not create cues. Personally I use dbpa and have never had any issues recreating as long as everything is setup correctly and you have the cue file.
