Bit Perfect Audio from Linux
Apr 5, 2016 at 2:32 AM Post #393 of 550
Also might be worth seeing if straight DSD plays properly with dsd_usb "yes"
not changing anything.
weirdly enough I can't get a log with mpd --verbose, there's also nothing in the folder "~/.mpd/log"
I'm now thinking of switching distributions because of this... thinking Manjaro
what are you guys running?
Apr 5, 2016 at 3:36 AM Post #395 of 550
Got manjaro at home for web app/ Dev/ daily use. Love it to death, can recommend.
I use headless arm players for playback though (cuboxi's).
cool, thanks!
I will test it this weekend and then decide if I'm going to install it on both of my machines
What DE do you use? I really want to keep KDE/Plasma
Apr 5, 2016 at 3:41 AM Post #396 of 550
Same. KDE user here as well, my only gripe with the default install is I don't like guake/ drop down terminals and its installed/ starts on boot by defualt but that took all of 4 seconds to remove. The default install is quite nice otherwise.
Apr 5, 2016 at 3:54 AM Post #397 of 550
huh, drop down terminals... never seen that before (I think).
How's KDE in Manjaro? It's incredibly well implemented in SUSE, never been more happy with it than with OpenSUSE.
Apr 5, 2016 at 4:33 AM Post #399 of 550
not in my opinion, SUSE is way beyond Kubuntu. Been using it for 2.5 years now never had any problem (aside from ALSA/mpd/DSD now).
looking forward to Manjaro, the things I've heard so far were only positive.
Apr 21, 2016 at 1:25 PM Post #400 of 550
found the solution to my problem:
Cantata does store a custom mpd.conf file under ~/.local/share/cantata/mpd/ which is used if at first setup option number one is chosen (simple setup).
I simply created a shortcut to the systemwide mpd configuration file and am now good to go.
Apr 25, 2016 at 9:55 PM Post #401 of 550
I follow those instructions. I have an EMU Creative DAC, but when I put a custom "hw:EMU0404" command inside alsa device in gmusicbrowser the music plays accelerated. If I clear that commend and leaves empty, plays fine. I'm trying to get the best sound I can with that nice soundcard. Any ideas how to fix it?
https://dl.dropboxusercontent.com/u/69141415/Screenshot%20from%202016-04-25%2022%3A45%3A13.png
https://dl.dropboxusercontent.com/u/69141415/Screenshot%20from%202016-04-25%2022%3A45%3A23.png
