Pricklely Peete
Franken modder
- Feb 17, 2008
Agreed ......the amp is a MeiXing MC34-AB.
I bought a new octet of Winged C's from Joe at the Tube Depot. I asked him to burn the set in in for 24 hours before shipping and to match them carefully (not that it matters all that much with the auto bias circuitry). The tube set will be a known good set. I don't anticipate any other issues frankly although I may be proven wrong. I'm hoping it's a straight forward repair though and it should be from other amp* failures I've seen far worse than this come back to life with a few parts swapped. (* Guitar amps mainly)
The blue glass tubes make it harder to discover early failure of a tube...in a dark listening room this combo may not be a good idea. Another set of tubes I'd like to try in this are JJ KT77 or Gold Lion KT77...that's down the road
The SED's should give me much better reliability over the standard life span of 18 months for a tube set. I take max life and cut it by 33% to be safe. The stock tubes for this amp, and the one that failed are Chinese Jinvina EL34 blue bottles...so anyone contemplating these...don't bother they have longevity and QC issues.
I'm still waiting on the tubes and other parts to arrive....I hope I get both tomorrow so I can get my beloved amp back up and running over the coming weekend.
I'll let you guys know what happens and will watch this thread closely if further info comes to light that I need to look into before hitting the power switch.
Thanks again for all the help thus far....
Peete.
EDIT: Here's a pic of the entire amp circuit...it's not the greatest quality picture, sorry about that.....
It has a full 4 input preamp which can switched out of the circuit on the front panel via a toggle(like the Triode/UL toggle). I use it in pure power amp mode only.
Originally Posted by dsavitsk /img/forum/go_quote.gif You should be able to trace it. There are only so many ways to connect EL34's in PPP mode. What is the amp, b/t/w/. Maybe someone knows the topology already. Anyhow, as I say, I would be weary about just dropping new resistors in there as they may be part of the protection scheme. Indeed, that resistor does not look like it baked over time and finally gave up. It looks like bias was lost, a tube ran away, and the resistor blew quickly as a way to protect the rest of the amp. You may be right that it was the last set and that they weakened the resistor, but I'd test the "good" tubes before you do anything. |
Peete.
