DirtyD916
- Mar 24, 2011
So the problem started with the volume drastically decreasing in the left earphone of my ipod whenever the slightest pressure was applied right above and to the left of the wheel. Once you pinched the area again the sound would be restored to the normal level in both ears. However now, 6 months from when it first happened) the problem seems reversed. Now the sound is decreased nearly all the time and is only restored when moderate pressure is applied to the region. The ipod already has a fairly new headphone jack and I know it has nothing to do with the jack itself. The earphones are also not the issue as 5 different headph
