chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
I put up the wiki page. I don’t know why this is in controversy. Let’s just agree to disagree.
Because DSD512 is very demanding, that even AK4499EQ in itself can only perform DSD256 in it conversion stage . So 128X Oversampling of NOS is 128x2=256.Well bad news. It looks like trying this has destroyed the Gustard! I have not returned the IDSD Pro Signature yet. Not only does it convert to 1024 it is real tubes. I was worried the tubes were difficult to replace. What do you guys think about this thing? It sounds insane.
No, the number 64 has nothing to do with bit depth and Nyquist didn't even mention bits. In fact the first published use of the term (computer) "bits" didn't occur until 20 years after Nyquist published his theory. And, 32bit is not a standard, 16bit was the standard for many years and then 24bit. When sampling twice 16/44.1, the result is 16/88.2.The number 64 derived from 32 bit depths. This 32 bit Standard is NyQuist standard which is when sampling twice the 16/44.1 to meet NyQuist theory.
Again it has nothing to do with bits. DSD64, the rate used for SACD had a bit depth of just 1bit, not 64bits or 32bits.So, Oversampling starting out from NyQuist which puts the bit at 16X2 = DSD64 ... So, DSD64 is the very first Rate of DSD format.
No, upsampling is just "upping" the sample rate, nothing to do with bit depths and nothing to do with the original frequencies either. If you increase the frequencies by 16x the result would be silence because even the bass frequencies would be in the ultrasonic range!Upsampling is when you increase the quantizations of bit depths and or original frequencies ,
1. Yes, an example of 2X upsampling.[1] for example upsampled from 44.1Khz into 88.2Khz. The sampling rate will have been changed. Or [2] you can upsampled 16/44.1 into 24/44.1
No, there are no square waves in PCM, either before, during or after conversion. DSD is only a format, it is not compressed and neither is PCM, although in a sense you might describe DSD as compressed because at 1bit (or a few bits) it has a very restricted dynamic range that requires aggressive noise-shaped dither.Conversions is when multi bit binary info is being modulated by sigma delta to become Square Waves before it becomes Analog waves. Digital to Analog conversion
All PCM will have to be converted into Square Wave before it can become Music.
Therefore, DSD is not only a format, but it is an Uncompressed digital music, where as PCM is Compressed digital music, which requires modulations to be uncompressed (DSD) before it become music
No wonder you misunderstand, your reference is just packed with nonsense. He doesn't even get the basic history right, let alone his explanations of how it works. Apparently Edison's wax cylinder phonograph was flawless, vinyl was a step backwards in fidelity and digital a further step backwards. Sure, and a modern supercar is several steps backwards from a donkey. How does anyone believe this stuff?
