mastercon12
- May 1, 2010
how do you feel about fixed gear/single speed?
BOTTOM BRACKET: | Sealed Cartridge Bearing ST |
BRAKES: | Shimano BR-M432 forged alloy linear pull |
CASSETTE: | Shimano HG-50, 11-32spd. |
CHAIN: | KMC HG-73 9speed |
CRANKSET: | Shimano FC-M443, 26/36/48T |
FORK: | NEW SR Suntour SF9-NEX4610 MLO, 63mm travel w/ Mechanical Lock Out |
FRAME: | Fuji Altair 1 Aluminum with PowerDiamond down tube, Integrated head tube, down tube gusset, double water bottle mounts; Fuji Altair 1 aluminum, cold forged dropout with replaceable hanger, rear carrier mounts |
FRONT DERAILLEUR: | Shimano Deore, 31.8mm Dual Pull |
GRIPS/TAPE: | Fuji Dual Density Kraton rubber |
HANDLEBAR: | Fuji Riser 30mm Alloy ATB |
HEADSET: | Ritchey Logic Zero Comp 1 1/8" Press Fit Integrated, 30mm spacers |
LEVERS: | Shimano BL-M421, 2 finger forged alloy |
PEDALS: | Wellgo LU-C25 w/steel cage |
REAR DERAILLEUR: | NEW Shimano Deore LX, Top Normal |
REAR SHOCK: | NA |
SADDLE: | Fuji Comp MTB |
SEATPOST: | Fuji suspension 27.2, 300 mm |
SHIFTERS: | Shimano Deore Rapid Fire Shifter Lever, 27-speed |
STEM: | Fuji Forged alloy, adjustable angle |
TIRES: | Continental Country Ride, 700 X 37c |
WHEELSET: | Rims: Alex, ID-19 double wall alloy, CNC side wall; Front Hub: Shimano Sealed Alloy HB-RM60, 32H QR; Rear Hub: Shimano Sealed Alloy FH-RM60 cassette, 32H QR |
Alright. I need a relatively inexpensive bike ( under 500) for a 5.5 mile commute to/from work. I don't know aaaanything about road bikes, any suggestions?
Also I'm 6'3"
^Obsolete technology, inefficient, basically a kid's bike - and a poor one at that. Even if you just want to occasionally ride it on weekends it still most likely won't be worth the money you pay for it. Save up and get a real bike - lots of good options available if you're willing to buy used. Also dealers often have discounts on previous year models.
Thanks for the advice Lord.Warlock!
I ended up canceling my order because I found a great deal on a 2008 Jamis Commuter 4.0. Alfine IGH, Shimano disc brakes, and everything else I need to commute and have fun! $599.99 for it. It is truly a beautiful bike. Now all I have to do is buy some hard core bike locks.
Here is the same make/model, just a bit smaller than mine:
