singular
- May 1, 2009
oooooh - love the XO-1. That was part of the inspiration for my Peregrine frame...
Originally Posted by singular /img/forum/go_quote.gif Hmmm, a 2000 era bike is likely to be designed for an 80mm fork max, possibly even 60. The measurement to compare is from the centre of the wheel axle to the bottom of the crown race (where the lower bearing seats on the fork). If it is more than an inch I would think twice about fitting it. This would slacken the bike quite a bit and change how it handles quite dramatically. The bike which fits you perfectly now no longer will. |
Set the air pressure at the mfrs recommendation for your weight and take it from there by feel. I'm guessing the 'solo air' means there is no negative spring ('specced for Performance' I suspect means simpler and cheaper for them...) so you don't need to worry about that. Basic forks lack the adjustability of better forks, so you can just get the right pressure, set the rebound damping to a level that feels right, then go ride it. Perhaps ask the shop if the can help you get the initial settings close, then tinker from there. |
Originally Posted by outlawdon /img/forum/go_quote.gif My ride...2009 Cervelo P2 |
Originally Posted by singular /img/forum/go_quote.gif oooooh - love the XO-1. That was part of the inspiration for my Peregrine frame... |
Originally Posted by lextek /img/forum/go_quote.gif Sweet ride! I started doing triathlons again after a 15 year break. Looking in to getting a tri-bike this season. Cervelo or Felt. |
Originally Posted by outlawdon /img/forum/go_quote.gif Thanks! I am more of a time trial cyclist as I don't swim nor run along with my weight training background. But I love the fact that time trial bikes allow you to be in the fastest and more aerodynamic riding position to cut through the air and wind. It's fast...when I do my part. |
Originally Posted by Raguvian /img/forum/go_quote.gif I love how the seat tube has the cut out for the rear wheel on it. BTW, is the seat post adjustable or is it permanently cut to height? |
Originally Posted by gore.rubicon /img/forum/go_quote.gif Question to the bicycle-fiers. How do you patch a tire so the tube does not jut out? Was riding today in beautiful 24 Celsius weather, when the tube stuck out too much from the lacerated tire, and I had a shameful walk home. |
Originally Posted by Lord.Warlock /img/forum/go_quote.gif The santos SCC03 Belt Drive. |
