Beyerdynamic T1 cable connection mod
Aug 26, 2015 at 12:45 AM Post #31 of 35
HI
IT RELY WORK ON MY T1 MORE AIR TO THE MIDS  HIGH  AND LOW BASS WENDERFULL SOUNDSTEG
THANK YOU
So what does all this mean? Are the shields also connected at the drivers end or not, and must they be removed from there too for this mod?  I am sorry if I cannot deduce the answer from the pictures, since my expertise and knowledge in such DIY projects is next to zero.
In spite of my non-expertise, I need to reterminate my T1 cable for use with a couple of HP amps that require the 4-pin termination for a balanced connection, which is why I am glad I found this thread, and why I am asking.  Thanks for any helpful input.
Nov 28, 2016 at 7:37 AM Post #33 of 35
What sonic difference would it make to use 2x 3pin XLR instead of 4pin? Does the cable shielding "function" properly without being terminated on both ends?
None
Mar 16, 2017 at 12:06 PM Post #34 of 35
I just wanted to thank everyone who contributed to this thread! I really appreciate the documentation on re-terminating the T1 in balanced mode!
Nov 30, 2017 at 4:17 AM Post #35 of 35
Did the 4 pin XLR mod. The wire colors can be different. Mine are:
LEFT:
White Wire - Positive Polarity (+)
Copper Mesh - Shield (Neutral)
Brown Wire - Negative Polarity (-)
RIGHT:
Red Wire - Positive Polarity (+)
Blue Wire - Negative Polarity (-)
