Beyerdynamic DT 1990 PRO // DT 1990 PRO MK II -- Impressions Thread
Sep 17, 2018 at 6:08 PM Post #1,966 of 5,026
Oh how I love you
Sep 17, 2018 at 6:16 PM Post #1,967 of 5,026
I hate spiky treble, and had to EQ the 1990's down between 7-8k in order to tolerate them. But the LCD-X seems a bit to the opposite extreme, in that they sound veiled.
Aw...I knew planar deliver more bass. But I love well delivered treble, there's a lot of detail up there, I want to keep nice detailed highs and jaw dislodging bass, I will continue to do my homework on the LCD-X. I love the bass on the DT-1990 detailed and deep, but my jaw is at no risk.
For the time being my DT-1990 sit at the top of my collection. Maybe electrostatics have maddening details and thick all the boxes on the bass department. I know firsthand the Sennheiser HE1 fulfill all of that in ways I didn't know were possible, but I'm at peace knowing that I may never aford those.
Moving on...
Sep 18, 2018 at 8:41 PM Post #1,969 of 5,026
Just got them, very early impressions.
Don't like the balanced pads - it makes the bass too wide and uncontrolled (at least with my FiiO E10K), and overall it doesn't seem to have the clear (treble-prominent) sound I want (if the treble is tamed, it doesn't sound "real" to me unless the recording is extremely good). I literally only listened with those pads for less than 10 minutes, so I could be off about the lack of clarity (I'm not off about the bass, though [to my ears]).
Switched to analytical (pretty easy to do once you read the instructions and just trust that the notch will work as you turn the pads), and this is more like what I expected.
There is definitely something like a hard edge in the treble. Sibilance is exaggerated, yes, not neutral - usually it is merely noticeable, instead of irritating, and most of the music I like doesn't have vocals, anyway.
Bass is significantly more focused than with the balanced pads, but there is (usually) enough bass for me, and it still goes into sub-bass territory that many other open headphones don't reach.
These headphones do texture, timbre, and detail very well. Obvious improvement over the ATH-M50x and DT-770 80 Ohm, and perhaps over everything else I own (see my first post in this thread for a list of most of my other headphones).
Instrument separation during busy passages (lack of congestion) is definitely an improvement over the DT-770.
Impact is good - drums kick when they should, etc.
With many recordings, there does seem to be a weird gap somewhere in the treble that reminds me of the AKG K701. Looking at graphs where the two headphones match up a bit, it may be in the 4-5.x KHz range? Maybe it sounds "missing" due to both headphones' uptick from ~6-10 KHz, since the DT-1990 doesn't share the K701's 2-3 KHz peak, but they both have this obvious (to my ears) hole in their response?
After a bit more listening, the treble can be a bit too harsh. Will try the balanced pads again. I've written enough, I think.
Sep 18, 2018 at 10:27 PM Post #1,970 of 5,026
IME, the Analytical pads have smoother highs, and sibilance can be reduced and even eliminated with careful choice of source, DAC, cables, and amp
Sep 18, 2018 at 10:45 PM Post #1,972 of 5,026
If you notice sibilance with the DT1990, in order to eliminate it your amp/dac would need some SERIOUS rolloff in the highs, and cables aren't going to do anything for it.
I've used Meitner Cryogenic interconnects and Cardas 300B Microtwin in my headphone system. They are polar opposites in tonality, but I doubt this would show up in a frequency response measurement.
Sep 19, 2018 at 11:18 AM Post #1,973 of 5,026
I prefer the DT-1990 directly out of my Samsung S8 to being powered by the FiiO E10K, as the treble peak/sibilance is quite a bit stronger on the E10K. Same story with the FiiO K5 amp, even with the S8 as the source. Unsurprisingly, though, directly out of the S8, bass extension suffers. I'll probably just install Equalizer APO on my PC and lower the peak that way instead of buying a new amp and DAC.
Besides worse bass extension, I really like how it sounds out of my Samsung S8. Pretty close to what I wanted from this headphone. No reason to go back to the DT-770 or ATH-M50x.
Sep 19, 2018 at 11:58 AM Post #1,974 of 5,026
If you underpower these headphones the sibilance does go away, but at a cost of great detail. Albeit I have enjoyed them in such matter as well. Good when you want to relax.
Sep 22, 2018 at 8:57 AM Post #1,975 of 5,026
OK these headphones are excellent. I recently got into Fleetwood Mac (REALLY late into the party) and man these things just sound amazing, Dreams sounds like nothing I've heard before. That wonderful rise and decay of the first cymbal crash, the meaty bass line along with the amazing voice of Stevie Nicks just nail down everything I like in a song. This is going to be my main headphone for a while.
Sep 22, 2018 at 1:42 PM Post #1,977 of 5,026
I have ordered the DT1990 - cant wait to try them :L3000:
But I wanna order one more can so that I can compare two against each other. I am unsure what to go for.
I have had the DT990 for many years so thats my starting point. I mostly listen to EDM (example below). What I like about the DT990 is the detailed airy sound. I sometime wish that they could be a bit more "impactful", a bit more presence in the deep bass.
I have considered the DT1770 but would prefer an open headphone.
What would you chose to compare the DT1990 with?
Budget: I would prefer below 600 dollars.
Amp/dac: Firestone Fubar III
Thanks and have a great weekend :)
Sep 22, 2018 at 2:03 PM Post #1,978 of 5,026
Check the Hifiman Sundara and Focal Elear (if you can find a good price)
Sep 23, 2018 at 10:19 AM Post #1,980 of 5,026
A cheaper option worth thinking about would be the Philips Fidelio X2.
Thank you for your suggestions.
Hifiman Sundara - Reviews seem to indicate that they lack bass a bit.
Focal Elear - Too expensive unfortunately.
Philips Fidelio X2 - Good option, should be good in bass, but lack a little in detail, from what I have read.
