Dec 23, 2013 at 3:41 PM Thread Starter Post #1 of 2
EndersShadow
Looking for possible options for a hardshell case for transporting my Beyer DT-770's to and from work.  I know there is the Slappa case (link) that I have seen used (example here).
I am curious if there are other options that folks are using.  I don't mind spending a couple bucks to keep these babies looking good. I would like if its got a way to attach a carabiner to it so I can attach it to my briefcase.
I am also debating doing this mod (link) to allow for use a custom 3.5mm cable to be used so I can make a long, medium and short one for using with different devices.
Thanks in advance and MERRY CHRISTMAS!
Dec 30, 2014 at 1:21 AM Post #2 of 2
Hey EndersShadow,
Sorry to revive an old thread, but I'm also looking for a case for my DT 770 Pro and am wondering if you've found anything good other than the Slappa one?
The Slappa one is too expensive for me and I don't wanna do mod to my cans. I found this one on eBay of $18 but the dimensions provided by the seller doesn't fit DT 770 Pro (He gave this info: 200mm x 190mm x 60mm).
Or anyone has good cheap case info to share with me?
Best,
