Best way to get audio from Macbook > SPDIF Coax > Modi 3
May 12, 2022 at 12:39 AM Thread Starter Post #1 of 7
prozonelayer
USA
I have a Modi 3 that is currently connected to my PC via USB and my Chromecast Audio via TOSLINK. I have a Macbook Pro that I use for work that I would like to connect to my Modi 3, but I'm not sure the best way to do it. I bought a SMSL PO100 last week hoping it would solve my problems, but the audio cuts out every 15-30. I'm wondering if it cut out because the bit depth and sample rate don't match what the Modi 3 can put out, but unfortunately the drivers on the PO100 for the Mac don't give me any options to change. Trying different USB cables, Coax cables, and ports did nothing.
From what I've read I have three options.
1. Find another USB > Coax dongle that does not have issues cutting out, maybe one better compatible with MacOS?
2. Find an HDMI audio splitter and go HDMI > Coax > Modi 3
3. Use a USB hub that both my PC and Macbook connect to, and then connect that to the Modi 3.
Does anyone have experience with any of these or recommendations? The HDMI audio splitter seems appealing to me, but there's a ton of options and none look particularly high quality.
May 12, 2022 at 6:54 AM Post #2 of 7
A simple one is to set the Audio Midi to 44.1 kHz and check if that helps.
Set the bit deth to the max allowed by the interface
https://www.thewelltemperedcomputer.com/SW/OSX/AudioMidi.htm
MacOS is fully UAC2 compliant, so any converter supporting USB Audio Class 2 will do.
As it is XMOS, I assume this to be.
Weird, I expect a driverless installation.
May 12, 2022 at 7:51 AM Post #3 of 7
Maybe something like this https://www.head-fi.org/threads/dou...or-an-affordable-clean-digital-signal.958462/
May 12, 2022 at 11:32 AM Post #4 of 7
Sorry I may have misspoke. The installation was plug and play, when I said "driver" I just meant whatever built in driver the OS was using.
I did not know about the Audio Midi program, thank you for pointing it out! Unfortunately though, I can only change the sample rate for the PO100, not the bit depth. I've observed this on my windows machine as well when I plugged in the PO100, the only bit depth available was 32 bit, which I found odd because the box it came in says the bit depth is 16/24, 32 isn't even printed anywhere on the box.
