nycbone
- Dec 30, 2008
I have:
A DVD player with audio line out, coaxial digital audio signal output and HDMI out.
An HDTV with HDMI in as well as audio line out and an optical audio signal output.
A preamplifier with line in only.
I use the HDMI connection for the video signal.
At the moment I run the audio line out from the DVD player directly to the preamp. It sounds fine (preamp is connected to a power amplifier/loudspeakers).
I just picked up a used Valab DAC in an attempt to improve the SQ.
I had planned to run the digital signal from the DAC to the preamp and be done, but realized...
I could also take the optical output from the TV and run that to the DAC. That would reroute the audio signal from the HDMI loop (DVD player to TV).
Any thoughts about one route vs. the other?
Thanks!
Thanks!
