The Zero can also be upgraded further with a Belkin PureAV F9A1033f filter/isolator/protector.
Bigger upgrade than any opamp. You can even plug your computer into it and get a mild improvement in sound in addition to the significant boost in performance that it will give your Zero or other external USB DAC/amp.
I read about it in this thread. I picked one up with ten outlets not long after for about $50. It also comes in 8 or 12 outlet versions.
The X-Fi Go Pro is known to have quite bad hissing issues, while the non Pro model has no hiss whatsoever, and has higher output settings (Go Pro-16/44; Go-24/48)
