Dept_of_Alchemy
- May 28, 2006
That's a nice budget to work with. Do you need the setup to be portable? If yes, look into high-end IEMs like the E500/530. If not, look into top of the line Sennheiser or Grado like the HD650 or SR325i or MS2i (used at ~$200, new at ~$300), if you go this route you will have enough budget left over to buy an entry level amp like the Original Master or the LDII++ at ~$180.
What are you using as your source? If you have a stand-alone CD player, then go with the amp+headphone approach. If you have an Ipod, then go with the high-end IEM approach. If you're using a computer/laptop as source then you might want to go with something like the HeadRoom BitHead (~$150 new) + headphone.
