Best triple flange or double flange tips?
Dec 21, 2017 at 1:33 AM Thread Starter Post #1 of 1
SMRDcompany
Hey guys,
looking for some replacement tips for my IEMs, I've found that the RHA double flange (large) do the job alright but I'm wondering if you've found a better option. I'm using a set of Musicmaker TK12 (chinese hybrids, pretty cool I suppose) which have a rather harsh and sibilant high range which I was able to mellow down with the RHA double flange. These have a bit of a bigger diameter than the stock tips that came in with the phones (stock is 4mm, RHA's is 5mm), and are quite longer because of the double flange, so I'm guessing wide and long should do the trick.
Primarily, I'm looking to try a set of triple flanges, any recommendations? Anything from 4mm to 5mm should fit. Thanks a ton!
