Bls440
- Jun 25, 2011
As mentioned, I have the iFi iDSD micro DAC/headphone amp. In my setup, I have the PC -> USB cable -> Schiit Wyrd -> USB cable -> iFi IDSD micro -> RCA out -> Schitt SYS (connected backwards by using the RCA out as input) -> Focal Alpha 65 (connected to IN 1). The reason for the SYS is to utilize it's volume control as a line level attenuator and flipping the two inputs as two outputs. The attenuation minimizes (almost eliminates the pops) and provides a bigger scale on the iDSD for its own volume control. This is required because at very low volume (9 o'clock to 11 o'clock), channel tracking is very poor on the DAC and I get barely any right channel signal. Now I can use 12 o'clock to 3 o'clock on the iDSD and turn the volume on the SYS for listening. Alternatively, get the Focal CMS 50 but cost a lot more.
I haven't heard the other DACs so I cannot say how they will sound but I like the iFi for PCM and DSD compatibility. You may even get by selecting the iDSD nano (it's a bit cheaper than the micro).
Cheers.
-H
You've got a very interesting setup, though out of my reach financially. Forgive my ignorance, but would the following scheme be relevant? PC -> USB cable -> iFi Audio Nano iDSD OR Audinst HUD-mx1 -> Focal Alpha 65 ?
Many thanks for your input!
