Linda513
- Mar 9, 2006
Will I get better sound quality on my ipod if I download music from the itunes music store, or copy it from a cd into itunes? Thank you,
Originally Posted by Linda513 Thank you! |
Originally Posted by ZackT Just to save you a bit of time. Can I suggest you try the 224 AAC setting? Bitrate has been talked to death here but I think most people would say that in a portable situation this is the best compromise between space/battery/sound. But do a search and read what others have to say. I use Lossless on my home computer (burning CD's etc) then convert to 224AAC for my iPod. ZT |
Originally Posted by Linda513 Zach - so before you transfer songs to your ipod, you convert them all to 224aac in itunes, is that correct? That will give you both versions on your itunes and only one on your ipod right? I tried the apple lossless and I didn't notice enough of a difference to justify the files being 8x as large. Must be these great headphones I just got. Linda |
