best sound quality for my microphone
Dec 6, 2015 at 5:58 PM Thread Starter Post #1 of 1
titousky
I bought a Modmic 4.0 : http://www.modmic.com/collections/modmic/products/modmic-4-0
It's a 3.5 jack microphone.
But my laptop integrated soundcard emit a lot of background noise when I speak on skype.
I need something I can put into my backpack.
Do you think thiswould be enough to get a sound without any noise :
http://www.aliexpress.com/item/PD310-USB-Karaoke-Microphone-Audio-Link-Mic-to-USB-Cable-for-MacOS-X-Windows-98SE-2000/1738009936.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_0,searchweb201560_6
Or
Should I get the blue icicle :
http://www.amazon.fr/dp/B001EW5YQS/ref=asc_df_B001EW5YQS30476452?smid=A1X6FK5RDHNB96&tag=clubic-rt-musicalinstruments-21&linkCode=df0&creative=22786&creativeASIN=B001EW5YQS&ascsubtag=referer_portail_thema
With a jack to xlr adapter : http://www.amazon.fr/Mono-Femelle-Fiche-c%C3%A2ble-Cordon/dp/B004HTII8Q/ref=pd_sim_267_1?ie=UTF8&dpID=41yUY%2B0PPRL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=06SQEXGH8X0VS4JEETQA
Is there any better portable option under 100$?
Tanks for your attention :)
