vermilions
- Mar 23, 2013
Hi everyone,
I want to buy a pair of speakers (2.0) for my home setup with my Macbook Air. I listen to a wide range of genres, most commonly electronic, downtempo, dance, indie/alternative, chill, modern rock, pop, R&B, soul, jazz and blues.
Main issue is size. I don't mind hight or width, just the depth must be less than 8" or 20cm.
I don't need to play music loudly. I will be sitting at my desk listening, and I want to be able to hear detail in lower to medium volumes if possible.
I also want enough bass but not room-shaking bass.
I will be buying a DAC along with this new setup, but at the moment I want to get the choice of speakers right first time round. I've researched and here's my list of small speakers that could fit my desk. Which would you guys recommend?
I'm still on the fence about passive VS active. I want the best SQ possible... so I guess passive is the way to go? I don't mind having an amp, which at the moment I know the Lepai LP-2020A+ t-amp is a good one to start with. Someone recommended I get a "2 channel receiver"? I'm not sure what I should get.
And I would love if someone could suggest some speaker amplifiers. It seems the O2/ODAC or Schiit M/M DAC/amp combos are headphone amps instead of speaker amps?
Thanks for all the help and sorry for the noob questions...
Cheers!
- Q Acoustics 2010i (203mm)
- Epoz Aktimate Micro (200m)
- Edifier RT1200T (183mm)
- Roth Audio OLi10 (178mm)
- PSB Image B4 (168mm)
- Cerwin Vega XD3 (165mm)
- NHT SuperZero (139mm)
- Fostex PM0.3 (130mm)
Cheers!
