HelIish
- Sep 28, 2012
I will have these in about a month and I am wondering the best method of connecting them to my pc.
Mymother board is the Rampage IV Extreme & soundcard is the Xonar Essence STX
Method 1: get a sound card that supports 5.1 the same way the sub can take it in and run all 5 speakers from the subs out.
(This will be really hard to find and seeming almost impossible)
Method 1b: Go from the Xonar H6/Xonar HDAV to the receiver, and then from receiver to each monitor / sub
Method 1c: Go from the Xonar H6/Xonar HDAV to each monitor / sub individually. (Other then cable management purposes this seems like a bad choice)
Method 2: Use a receiver and connect to the receiver from my essence stx (and then all out of receiver I believe not all to sub then monitors)(A receiver is also not the first choice as it will be taking up more space)
Method 3: Xonar DX with size adapters
Method 4: Use the 3.5mm input (not happening, but could potentially be for temporary use while tracking down the Xonar H6/HDAV)
Or if you have any alternate methods that may be better please let me know thanks. The goal is best sound, budget is not that much of a concern, but size is a concern and that is why 6010a's are being used.
