wdahm519
- Aug 11, 2010
[size=medium]
Hey guys, I've gotten addicted to detail. I need more detail in my portable set up now. I'll be running an iPod with Apple Lossless files only, and a self-built amp which sounds pretty neutral so nothing to worry about there. I read a ton about different IEM's. I made a list, I refined that list, and then deleted the most expensive ones (the ones that were about $380+ since I just bought HD650's and Silver Dragon cable).
My list is:
Earsonics SM2 DLX
Etymotic ER4s
Fischer Audio DBA-02
HiFiMan RE252 (262 any better?)
Ortofone e-Q5 (read they're a little better than e-Q7's?)
Westone UM3x
Westone 3
My question is, what is the most detailed IEM that has the best soundstage on this list? If you can think of something significantly better (I've probably read about it), and under $400, please let me know! Thanks.
[/size]My list is:
Earsonics SM2 DLX
Etymotic ER4s
Westone UM3x
Westone 3
