Aracconan
- Jun 22, 2013
Hello,
So recently I've decided to buy a new set of headphones, but I'm not quite sure which one will best suit my preferences.
The factors that I'm considering are (from top to bottom in terms of priority):
1. Really good sound quality on female vocals; light, warm, and organic
2. Good sound quality of orchestras, especially piano and strings
3. Sort of weird to describe, like a pair of headphones that I can turn the volume up, and it'll fill my head like if I was in the recording studio
(Would this be referred to as having a big sound stage? I've seen that term a few times in the forums).
4. Comfort
I should also note that an exceptional bass is not a factor I'm considering (since it's not really important in Jpop/classical)
Examples of what I listen to:
http://www.youtube.com/watch?v=i67ZXLPeg9s
http://www.youtube.com/watch?v=_HyCUr95LEU
So far from looking around the forums, I've seen a few recommendations:
1. Audio-Technica ATH-ESW9A
2. Audio Technica AD900x
3. Audio Technica ATH-M50
4. AKG Q701
5. AKG K601
6. Sennheiser HD 598
I'm wondering, among these, which would be the best for my preferences? Also, if there's another headphone that's not listed here, but is also really good, please don't hesitate to recommend.
Thanks!
EDIT: Through a bit more research, I've found that the Audio ATH ESW9A and the AD900x are probably my best options right now cause I can find deals on them. Which of the two would be better? (Unfortunately, I can't expand my budget for the HD 650)
4. Comfort
4. AKG Q701
5. AKG K601
Thanks!
