Bradrj1029
- Sep 10, 2008
You could spend an extra 50 on top of your limit and get the Logitech z5500s, I have them and they are amazing
Are you trolling?
Thanks for the replies again. So A5 is not overkill for my room size? Also, I have been reading that there should be a good amount of space between both speakers. Why is that? Placing them next to my monitor going to affect the sound quality in any way? Also do I need to invest in some speaker stands? As for my previous question, what stores in U.S would have these speakers so that I may hear them?
Thank you
Bradjr1029 said:umad?[\quote]
umad?
Thank you
I dont understand why people keep saying they are overkill. just dont turn the dang things up to 11....I keep mine at 25% and have windows control the volume at a pleasant 12%. Alternatively, i can turn windows volume to 50% and have the speakers control the volume, but I find that its easier to adjust the volume on my laptop than it is to bend down and fiddle the knob.
You need lots of space between the speakers because why would you have stereo speakers if you are going to put them so close together that it sounds like mono? Placing them next to your monitor will not affect the sound quality, but be careful with your volume because you are likely to blast your ears off if you accidentally turn something up too loud. these things dont play around.
You dont need to invest in speaker stansd, but considering the ideal environment for them is spaced apart, you would want them on the floor and on those little 15 degree 15 dollar inclines that audioengine sells. Personally, i have mine about 6 feet apart at my feet next to my desk on the floor without any sort of stand and the only problem ive run into is that my desk creates a huge resonant frequency range in the midrange, which I can solve by angling my speakers outwards or down into the carpet.
I dunno about where to buy them in stores, but they are small and so ridiculously well packaged that I doubt a store would let you take them out of the box and have a listen. Also I dont know what stores are in your location. I bought mine off of amazon with the mindset that if I didnt like how they sounded after 1 day I'd just return it to amazon. I threw out the box within the hour.
You have them on the floor? You know you would get much better sound out of them if they were on your desk, with the tweeter about the same height as your ear.
my desk is only 6 feetx2.5 feet....there isnt any room for them on my desk. I'm still brainstorming ideas on how to get them to face level without attempting to remodel my parents' house/furniture
