GerGa
- Apr 1, 2010
Hi,
Background: I am getting Mogami 2893 quad cable to make a cable to connect to the back of my new car headunit(RCA) to a pocket in my dash(mini) where I can stash my Fiio X5II.
I would also like to make a mini to mini cable in case I want to use 3.5mm aux port that comes on the front of the headunit. What cable should I get? I would use the Mogami but it a 4 conductor cable. I do think a shielded cable is good because it's in the car, though. I need a 3 conductor cable for mini to mini, correct? Only reason I ask is because it's never a bad thing to reduce the size of a cable when it is used as a aux cord in the car.
Also,
For the shield on the RCA cord connected to the back of the headunit, what do I connect that to? Will I be fine to just connect it to a near-by ground in the car(aka a screw in the car body). Seems like it would be a better ground than any other option; even case ground on the stereo.
And the shield on the mini to mini cable, do I bother connecting it to anything?
Thanks
Also,
Thanks
