Hi John,
so there is no way to downgrade the 1.0.1 firmware units back to the older software version or somehow fix large characters in the balance menu?
If I try to turn off the large characters, the issue is still present.
NOTE the distinction between
FIRMWARE and
SOFTWARE in this post!
The
SOFTWARE is the downloadable screen software and is the first number shown on the "ABOUT" screen.
The
FIRMWARE is contained in a ROM on the main board and is the second number shown on the "ABOUT" screen.
Old units (prior to 11/05/2018) have 1.0.1
FIRMWARE. All newer units have 1.0.2
FIRMWARE.
The solution is actually simple:
Units that were made prior to 11/05/2018 can be updated to current 1.0.2
FIRMWARE (not SOFTWARE) by installing a ROM kit:
HPA4 Firmware Update Kit
The cost of the
FIRMWARE kit is $59.00 including shipping. If your unit is still under warranty, call Rory or Dan in Sales and they will send you the kit at no charge.
After the FIRMWARE kit is installed, the screen
SOFTWARE can be updated to version 2.2.1
For those of you who installed the
SOFTWARE without first installing the 1.0.2
FIRMWARE, your unit should start working properly as soon as you install the
FIRMWARE chip.
The current
SOFTWARE version is 2.2.1 and is available as a download.
The current
FIRMWARE version is 1.0.2 and is available as a chip, and is only needed if your unit was manufactured before 11/05/2018. Units manufactured after this date will not need this kit.
Do not attempt to install 2.2.1
SOFTWARE in a unit that has the old 1.0.1
FIRMWARE. If you do, the BALANCE screen will not work.
Version 1.0.2
FIRMWARE should support all future versions of the HPA4 and LA4
SOFTWARE
