John Siau of Benchmark has previously stated this:That’s a good suggestion.
Now, would you, or somebody else, be able to just check whether the neutrals on your rca inputs are floating or if they are earthed (to the mains earth pin, or to the rca outputs for example)? (Mine are not and it seems to cause problems). Would be much appreciated!
"The incoming RCA ground is connected to HPA4 chassis ground through a 30-Ohm resistor. This resistor limits the current flowing through the RCA shield between the two audio devices. This greatly reduces the ground-loop currents between the two connected devices and minimises the ground-loop-induced voltage across the two ends of the RCA shield. "
FWIW, I have an AVR and a tube phono stage connected to the RCA inputs of my HPA4 and don't have any issues. As John suggests above the 30ohm resistor should make the RCA shield path far less inviting for ground loop currents.
