TheVinylRipper
- Jul 12, 2007
Ben Franklin and US Grant get you this system here.
http://www.amazon.com/M-Audio-Studio...8537196&sr=1-3
http://www.amazon.com/Yamaha-YST-SW0...8534634&sr=1-5
This system here will run you about three Ben Franklins and will rock your world.
http://www.amazon.com/M-Audio-Studio...8532999&sr=8-2
And you use two of the Yamaha subs above.
Both sets of speakers have amps built in and so does the sub, just plug 'n play.
With both systems you will have to do your sub crossover in the soundcard software drivers.
With the cheap system, you will probably want to crossover at 110 - 140 hz, the higher the frequency the more you can locate the subwoofer but the clearer the sound from the monitors will be and the louder you can play them. What you do is lower the crossover point until you can't audiolocate the sub any more. You can play with the settings with different music. Adjust it some, listen a bit and keep going one way until you are past the point where you can barely locate the sub. When you get there, you can slowly turn it up.
With the expensive system you lower the crossover frequency to 60 - 120 hz give or take a bit while listening to how the bass sounds to you and what you like.
The Yamaha subs are particularly nice for the price since they have servo feeback, something that tightens up the bass a lot and is usually only found on more expensive subs like a Velodyne.
Then you can EQ all you want to get the whole thing sounding right.
You can tune both systems to the room by putting the sub(s) in the corner(s) of the room and moving them out a bit at a time while listening to how the bass sounds.
