Originally Posted by Dexdexter /img/forum/go_quote.gif
So now that I've gotten a taste of what the Go-Vibe is capable of with a 24V external power supply, I'd like to take that same magic on the road, as it were.
I've noticed that most common rechargeable 9V batteries actually measure 8.4V. So I was wondering if making a battery pack of 3 such rechargeables in series (25.2V) would be a workable solution or an invitation to certain amp-failure disaster.
Thanks in advance for your help!
Dex
Actually, if you go for the true 9.6v NiMH batteries, such as
Maha they measure close to 11v when fully charged, and don't drop much below 9v before running out.
If you feel the need to construct an outboard battery pack, then two x 9.6v NiMH batteries in series would be ideal.
Your 3 x 8.4v NiMH batteries would likley measure more like 27v. This is OK for the LM6172/71 op-amps, but not for some of the other op-amps now offered with the V5, and not for the 25v power supply cap.
The AD8397/AD825 version is restricted to a maximum of 12v DC so one single 9.6v NiMH is about it.
Be very careful of polarity when you hook this battery pack up to the amp, presumably via the DC jack. There is a reverse polarity diode in there, but it is designed to protect the amp against wrong polarity for external DC power supplies. Two 9v batteries put out a huge amount of current and will destroy this diode very quickly. The result will be catastrophic for the amp.
So, when you construct this battery pack, make sure to measure the voltage and polarity with a meter before connecting it to the amp.
24vDC maximum voltage and centre pin positive polarity.
