Battery in Vision M
Jul 4, 2007 at 6:18 AM Post #2 of 12
Yes. There are web sites that tell you how to do this...i can't remember the link.
Jul 4, 2007 at 4:26 PM Post #4 of 12
find a video on youtube about it
Jul 4, 2007 at 7:53 PM Post #6 of 12
If you are planning on using an amp, get the zvm. Otherwise the zune is a very good option, as the headphone out is superb! I like the interface of the zune a lot better than the zvm, but the zvm has a lot more options...if you are on the go, and don't need an amp, I feel the zune would suit you better. Thats just my opinion though.
Jul 5, 2007 at 1:14 AM Post #8 of 12
Sure! The zune does respond well to an amp, but the zvm SQ is superior amped.
Jul 5, 2007 at 3:21 AM Post #12 of 12
Originally Posted by kikkomang /img/forum/go_quote.gif
the zv:m's battery isn't user removable like the sansa e200 as you need to open the player up and kill your warrenty.
By the time a ZVM will need a new battery (couple of years at least) the warranty will be long gone.... so not an issue at all.
