Batch-converting w/foobar.
Mar 20, 2010 at 11:30 AM Post #16 of 18
Originally Posted by Punnisher /img/forum/go_quote.gif
Strangely, my tutorial here doesn't seem valid for the new version of foobar. Clicking the converter field under preferences doesn't bring up all the options. Instead, I can access all the options by highlighting the files I want for conversion, right click them and select convert , ... Then all the directory settings are displayed. Strange....
Yes. The field is now found within the conversion utility menu when you right click to convert. But once you have changed the naming string, you can just select "last used" each time (until you need to make further change such as to convert compilation albums).
Mar 20, 2010 at 11:34 AM Post #17 of 18
Originally Posted by Chri5peed /img/forum/go_quote.gif
Personally I turned all my FLAC-albums into single file V0-mp3s...mainly so they're gapless.
If you rip an album in EAC to a single FLAC image file with cue sheet and then convert to Lame MP3s in Foobar, those MP3s play gapless. ALAC files ripped with iTunes that are converted to Lame MP3 files in Foobar also play gapless.
Mar 20, 2010 at 7:25 PM Post #18 of 18
My D2 DAP is not gapless. Its the player which adds gaps, so downloaded music are seperate files. I do rip w/EAC perfectly.
