Metaphysix
Tidal over Schiit Hel 2E (usb) with Beyerdynamic MMX 300 / HiFiMan HE-4XX
Been running the above amp / cans for some time and regularly switch between a Lenovo X1 Carbon and my work Dell laptop. Never particularly noticed any difference between the two laptops and figured there shouldn't be any since the Hel is doing all the work.
Just swapped out the X1 with a newer Lenovo T470 with a fresh Win10 install and immediately noticed a reduction in bass.
Checked all settings in Windows and Tidal, reinstalled drivers, applications, etc. to no avail. Had actually missed some optimization of settings on the X1, but even with everything matching, there's a clear difference. As far as I can tell there are no "optimizations" / EQ or filters applied.
Detail / quality is still very much there, just the balance feels way off what I'm used to. Found some references to sound issues on the T470, but all related to onboard sound, any reason this should be a factor in my setup?
Appreciate any suggestions on where to go from here.
