drewd
Banned
- Apr 26, 2004
Try looking at the equation under two conditions - as f approaches zero and as f approaches infinity.
It reduces just like that. By looking at the equation's behavior as it approaches the two frequency extremes, you should be able to see that it's correctly modeling the way that the circuit works. You don't have to toss j because it is integral to the capacitor's function - and at the frequency extremes, you get this:
Ao = (Rbb+R4)/R3+1 as f approaches zero.
and
Ao=R4/R3+1 as f approaches infinity.
Instead of zero and infinity, just think low and high frequencies. So for low frequencies, Rbb is in play, effectively increasing the gain of the system. At high frequencies, Rbb is out of the circuit, so the gain approaches the normal gain without the bass boost.
Now, tossing j, you should be able to observe the shelving function of the circuit in terms of gain, assuming that you are using a log scale plot.
Let me throw in this caveat that it's been a few years since I did any signal analysis by hand and that was in college, where everything was nice and predictable.
-Drew
Originally Posted by morsel Hi Drew, thanks for your reply. I tried what you suggested about a month ago and plotted it, but the graph is a regular low pass filter, no shelving. I think there should be multiple exponentiated terms. |
Originally Posted by morsel This is how I reduced the equation: Ao = (Rbb||Cbb+R4)/R3+1 Ao = ((Rbb/(2πfCbb)/(Rbb+1/(2πfCbb))+R4)/R3)+1 Ao = 1+(Rbb/(2πfCbbRbb+1)+R4)/R3 Tossing j is legitimate in this case, right? |
and
-Drew
