comabereni
- Aug 1, 2004
This thread isn't that old--I think I started it yesterday morning
Ah yes, the remote desktop! This keeps getting better. And as for booting Windows from CF cards--yet another great idea, especially if all the remote PC's are playing from a central music server. This ensures almost dead silence (except for six tiny CPU fans turning behind a panel). I already estimated I can run 2 or 3 mini-ITX M/B's off a single, higher watt fanless PSU.
Thank you for your suggestions!
Originally Posted by Frenchman I realize this thread is a bit old but I think I might be able to suggest something neat thing for you. Your setup sounds exactly like what I'd do with one exception. There is no need for a local keyboard and mouse ever after the install. Simply install VNC or use XP Pros remote desktop. That will make things much easier for admin after the boxes are installed. This also means you don't have to reboot. Also, if you don't mind getting less MB for your buck but value the silence, grab some compact flash cards to install instead of hard drives. Part of their standard is operating at ATA devices so you can boot right off of them. |
