Pageygeeza
- Dec 1, 2009
I'm not too great at explaining things, so I'm probably not saying the right things to be understood.
The way I see a balanced setup, or at least how I would prefer it to be:
Each channel has a +/- connection as opposed to say L/GND or R/GND. When current runs from neg to pos the voltage is below 0v and if it runs pos to neg then the voltage is above 0v. Is this the voltage swing?
I'm assuming that this would be the same for L/R channels? So that would be four channels. The way I see the current is like a belt around two wheels, the belt on one side of the wheels is + and the other -. So if you pull one side the other side will go in the opposite direction. So it's going full circuit, from the dac through the amp through the headphone back through the opposite amp and back to the DAC and flowing until it swings in the opposite direction.
I don't think it's the balanced i'm not understanding, I think it's the output of the DAC itself. I know the DAC has L+ and L-, so the current would need to flow from one to the other. If the ground is used as a reference, it's still shorting L+/L- out. So it should still be balanced.
