music_man
- Jun 6, 2005
So a Toslink cable broke off inside the jack. Any way you guy's would go about extracting the piece? it was in right, must be bad cable. Since it was in right it is lined up and stuck in there good. Last thing I want to do is break this component more! Under warranty but not their fault and a big hassle. I figure something can just pull it out but not sure what. or what exactly you would do to get the piece out. luckily it is not a jack with the door on it. I have one idea you tell me if it is a good one. put super glue on the cable itself, insert it let it dry and pull the whole shebang out? Actually if I do that and it works is that cable still good then? that was a $1,300 cable. Not sure about light leaking or whatever. It is currently working but if need to toss it(no pun) oh well. Thank you guy's.
