hanalei mike
- Nov 26, 2007
I just had the same problem when I received a new amp and hooked it up. I spent 2 evenings trouble shooting for 6 hours, switching amps,preamps,power cords, cables and interconnects, different power sources etc. My wife thought I had lost it, 11:30 at night outside in the Hanalei rain on a ladder with a headlamp cutting trees away from the power poles???
Anyways, my advice (actually my friend John's who is a class a electrician) is try and find a new ground that is not hooked up to the building power. If you are on ground floor, run a cable from your neighbors. Even better, pound a long bar into the ground and run your ground to it. If you are not on ground floor this obviously wont work. Maybe try a small honda generator. The newer models are supposed to have quite clean power and can probably be rented at any rental place.
good luck, I know how annoying it is.
It turned out to be an old cable wire comming to the house from the pole. The output was connected to my amplifier, and the preamp was connected to the amplifier, so once I unplugged the cable connection, it was fixed.
I cancelled cable. It sucks anyways.
