Back ups = loss of sound quality?
Feb 22, 2006 at 5:29 AM Thread Starter Post #1 of 9
Mokpie
I've made a back up of a couple CDs I own so that I can use them on the road and not worry about losing them etc.
My question is, is there a significant loss in terms of sound when going from the original disc to a copy made by your computer?
thanks
Feb 22, 2006 at 5:38 AM Post #2 of 9
If you are using a quality burner, there should be no problems. Burners that have good reputation are NEC, LG, Plextor. Anything else is largely hit-or-miss, with e.g. Sony being pretty bad in terms of error rate.
Feb 22, 2006 at 7:40 AM Post #5 of 9
You should use EAC. Properly set up, it should be bit perfect.
Feb 22, 2006 at 12:11 PM Post #6 of 9
Yep, what he said.
Feb 22, 2006 at 12:24 PM Post #7 of 9
Bit perfect is ok with an entry level setup, I guess, but what if you are really into high fidelity and want nothing short of nanobit detail? Huh?
(For those who don't know what a nanobit is, it's a 1000.000.000th part of a bit.)
Feb 22, 2006 at 1:32 PM Post #8 of 9
Then use Roxio Toast Titanium and get some of those black-vinyl CD-Rs.
Feb 22, 2006 at 3:52 PM Post #9 of 9
yes, if your high-end cd player uses the decimal binary system, precision up to the nth nanobit is a must.
uhm, sorry
back to topic, there are two possible ways to screw up a backup: one is when ripping, the other when burning. but even if the copy isn't 100% bit-perfect (there might be errors because of bad scratches) the difference to the original should be negligible as long as decent recorders and media are used.
