oneplustwo
Member of the Trade
- Jan 27, 2009
Gotcha. That makes sense. Again, thanks for the education!
Originally Posted by DoYouRight /img/forum/go_quote.gif Thank you! This was pretty helpful, I am in the process of a 6 board to be fed by a balanced buffalo32 |
Originally Posted by oneplustwo /img/forum/go_quote.gif 1. When wiring for SE output, would it be best to drive the both combo jacks from R+, L+ only? Or should I drive one with R+, L+ and the other with R-, L-? I think the latter makes more sense. |
2A. Should the RCA input jacks be grounded to the enclosure or should they be isolated? I think they should be grounded to the enclosure based on having the sigma and toroids in a separate enclosure. |
2B. Should I just connect the RCA and XLR input jack grounds together (to the enclosure)? |
Similar question for the combo output jacks? Should the XLR pin 1 be grounded with the TRS jack "S" pin and then to the enclosure? |
3. The schematic Amb has shows where all the board input signal wires go but how about the board input ground wires? For the wires that go to the volume control, I can just connect them to the ground terminal block of my TPA joshua tree attenuator. But I'm a little confused as to what to do with the ground wires when they go to the switch. I think I can just connect them to the same ground terminal block on the attenuator. |
