Arlekiin
- Apr 26, 2009
Hello,
So I'm having a difficulty in determining the real cost of a proper 3 channel B22. Or is there a real point in going 4 channels from the start?
At the moment my price ceiling in parts is around 1-1.5K USD and I was planning to get a Wooaudio 6SE but since I use amps alot and may forget them on from time to time I think using an expensive valve amp as a main amp would prove expensive if you burn through Princesses like matches.
In conclusion I have decided that B22 would be a proper box for me and would cover many of future needs for headphone amplification.
So if I you could let me know how much you planned to spend on your B22 designs and how much you actually ended up spending because I bet these numbers can differ quite abit also lets assume that the case is simple but functional no need to count in gem encrusted marble coffins
Thank you for your time...
