Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
- Sep 28, 2003
Quite so.
I did some experimenting with this a while back.
Took some 18 gauge zip cord and in one leg, I patched in a 1/8" TRS plug and jack. Across this I wired in a 1/8" TRS jack, combining the tip and ring on the one side, and the sleeve on the other.
I terminated one end of the zip cord with an 8 ohm resistive load and plugged the other end into the speaker outputs of a little JVC mini system I have.
Then I plugged a pair of cheapie headphones into the jack across the plug/jack combo.
Turned up the volume a bit and sure 'nuff, there was Wynona's Big Brown Beaver just as pretty as you please. Turned the volume up all the way and was able to get some pretty moderate output from the headphones.
Though to be fair I was running about 5-6 watts into the load.
k
Originally Posted by jcx /img/forum/go_quote.gif the TRS contact R on the common "gnd" can exceed 10 mOhms - a much bigger source of "gnd contamination" crosstalk - not cured by any active gnd scheme discussed here |
Quite so.
k
