Hi
I have the SE530, Sony NWZA829 & Ipod Touch, all files are 392kbps
On the Sony NWZ-a829, they sound awesome, warm, bass’ incredible detail and when you turn the volume up, its a balanced increase. The SE 530 compliment its great little player.. The sound makes me smile..
On the other hand
When I plug them into my Ipod touch, well they highlight the difference in player quality, for some reason the touch dismissed the bass no matter what setting I use and I am not talking about heavy dance tracks, im talking alternative, pop, Rock etc.. And when you turn the volume up well it make me cringe as only the high to mid tones seems to rise..
BTW: there is a good seal on the headphones as i performed the comparison at the same time and there was plenty of low tones with the Sony.
I guess the bottom line is that the ipod have always sounded anaemic to me compared to other brands eg Sony, Iriver, Iaudio, creative etc etc and these earphones highlight the inadequacies of the Ipod, maybe a mid range set will fulfil the potential without highlighting its weaknesses...
R
SB
