superjawes
- Apr 2, 2014
This is not what is being said....what I've read by neuroscience definitely suggests strongly that the amount of information isn't at risk of overloading the ability of neurons to process...
Any audible waveform can be represented by a combination of sinusoidal waves at various frequencies. In order to adequately reproduce any given frequency f_0, you must sample at a frequency of 2*f_0 or higher. Once you're above 2*f_0, you have all of the information necessary to reproduce the original frequency.
The highest frequencies that humans can hear are somewhere between 20 and 22 kHz. So in order to capture all of the audible frequencies, your minimum sampling frequency needs to be 44 kHz. Sampling at a higher rate captures information from frequencies that are inaudible to humans, but it has no effect on how accurate the audible frequencies are.
Basically higher sampling rates increase the total information in the audio file, but they do not change the audible information.
