bavarianblessed
- Jan 11, 2014
Maybe I'll have better luck here,
Anyway, I have a Forte that "died" on me a year and a half after buying it. It started emitting a hella loud clipping noise when powered on for more than 5 minutes so I pulled it out and replaced it with a cheap Asus Xonar DGX. Anyway, fast forward to yesterday and I thought I might see if I could get it running again. All the standard radial caps (not can) on the board are crappy sam young caps. I had some Nichicon KT audio grade caps that matched the power supply cap values so I swapped them out and voila! The card works again
Now my question is this: Would the caps that I replaced, circled in red here, be better off if I used something with a lot more ripple and lower ESR or are the KTs good enough to do the job? I know different amplifier types require different spec caps. The stock values are 16v 470uf so I was looking to swap THESE for the KT series.
