BigSurSpoon
- Jan 4, 2007
I just use the digi out with no effects and everything flat, so it doesn't really matter what mode I'm on. It just so happens to be Game mode.
Originally Posted by Sduibek /img/forum/go_quote.gif 1) First, double-click the Auxen icon in yoru system tray. 2) Once this screen is loaded, click "Snapshot" in the top right and select "RMAA 2496" 3) Next, assure you are resampling in Winamp. If you don't complete this step, your output *will* be 44.1kHz and then the soundcard's software will notice that, and adjust its own sample rate to match. |
Originally Posted by BigSurSpoon /img/forum/go_quote.gif I just use the digi out with no effects and everything flat, so it doesn't really matter what mode I'm on. It just so happens to be Game mode. |
Originally Posted by somestranger26 /img/forum/go_quote.gif ^ Bus routing just does what the name implies, if you set the front to route to the front and rear, identical streams will be played on both. So I'm not sure what you mean the sound is fuller with deeper bass, since it should be the same. Maybe it's causing headphone mode to disable or something, because "headphone" mode sucks Audio Creation Mode, bit perfect output, 2-Ch. |
Originally Posted by somestranger26 /img/forum/go_quote.gif I'm not sure what you mean the sound is fuller with deeper bass, since it should be the same. |
Originally Posted by Sduibek /img/forum/go_quote.gif At the top-right where it says "Snapshot", click on that and then click on RMAA 44.1kHz |
Originally Posted by OpTicaL /img/forum/go_quote.gif Do I still have to select RMAA 44.1kHz under "Snapshot" when I already have 44.1kHz enabled under settings? |
Originally Posted by OpTicaL /img/forum/go_quote.gif Lastly, regarding Game Mode, what is the purpose of "Upmix" under X-Fi CMSS 3D? I notice this option is not available in Entertainment Mode. |
Originally Posted by Sduibek /img/forum/go_quote.gif I don't have that option |
Originally Posted by OpTicaL /img/forum/go_quote.gif I'm using X-Fi Fatality with the lastest Creative Sound Blaster X-Fi series Driver 2.18.0008 It's the Upmix option right under Upmix Mode in Game Mode (see pic). That option is not available in Entertainment Mode and not sure what it does exactly. |
